I went through all the fuel and ignition systems today just to test and make sure they were all working properly as I have a misfire in cylinder 2.
The Ignition system was a bit corroded here and there, nothing too serious. I cleaned it all up, also discovered I had a bosch electronic ignition. A couple of wires were loose from the control module to I re-soldered the PCB. The timing was fine and all plugs had a spark.
I got to the fuel system and found that the air bypass screw for cylinder 1 was screwed fully home, although I am not sure of correct adjustment procedures. Is this normal?
I also found that the fuel mixture screw for cylinder 2 was missing. Obviously I need to fix this problem. Will a rebuild kit contain one?
Easy fix to what could be a complex problem! :lol:
