it should be possible, just have to make sure its out of the same model ie jts 2.0 selespeed or v6 manual, otherwise if your careful you can open them up and pull the needles off and remove the faces and put them onto your original.
also it is likely you may need to see a dealer to have them reset the speedo as it can be dialed up to suit your vehicle and carry out the proxi alignment procedure so that the odometer does not flash.
