Hi Everyone
Couple of months into my "new" Alfa with a few issues....Car need two new lambda sensors which where fairly easy to change. However.... I have an occasional throttle problem that causes car to run on limp mode. Quick diagnostic check showed "improbable throttle position". ECU re-set sorted this. Long term I want to check throttle connectors or hard wire. My main problem is getting to the throttle pedal electronics. I noticed that most of it is hidden behind the fuse box bracket. Is there any easy way to access?.Any advice regarding sorting this issue? Thanks in advance
