I want to replace the tophat bushes on the gear change mechanism above gearbox.
The shaft (1 & 2 on photo) that I need to remove to get to the bushes, at one end is fixed to a linkage, to which another linkage rod is also attached (2 & 3 on photo).
I've undone the nut and tried to tap the shaft out, but the shaft was not separating away from the linkage at (2), but pushing the linkages (2 & 3) away.
Question, is the shaft just stuck at (2), or do I need to remove the linkage rod at (3), then remove shaft and linkage between (2 & 3) in one piece?
