1 - 2 of 2 Posts
...mine needs replacing, cut out today after starting to misfire, had new coil packs and plugs so seems the logical thing to have failed.
Is it a reasonably straightforward job, have access to car ramps so getting under the car is not a major issue and have good selection of tools at my disposal
Yes. There's a connector plug and a couple of bolts (maybe hex head) and that's it.
Make sure that if the new one has an o-ring on it, that the old one also has an o-ring on it. If you take the old sensor one out and the o-ring stays stuck in its groove, the new sensor won't fit close enough to the pulley to do its thing. So.. make sure you remove the old o-ring. That's all.
Ralf S.
1 - 2 of 2 Posts
