Hi guys anyone breaking a v6? My abs sensor has failed in the driver side so looking for a v6 replacement hub as sensor is all rotten and don't think it will come out.
Thanks Jon
Thanks Jon
Hi replaced my sensor last month only use genuine part (£110) as eBay parts will only work for 6 months if at all as I was told by a reliable source,had to pilot drill and use extractor tool to remove old sensor.Don't fancy drilling them out, anyone know if the v6 are the same as the ts
+1 my local Indi says he almost always drills them out on most makes!Strange they said that. The sensors are mostly plastic with some wire and metal inside and not that difficult to remove if duff and you can butcher them.
