The electronic controls to release my boot-lid, petrol filler flap, and headlight adjustment have all suddenly stopped working!
Is there a fuse or relay that controls these?
In the manual it says headlamp aiming device, which is headlight adjustment i believe is on f5 fuse along with the plate light, cluster lights and so on... it could be that some other is blown and is causing you issue like it did in my case, check every fuse u can find
Hi
Thank's for the advice but I had already tried that.
It turned out to be the N82 ECU. I've found one at £40
Hi
Hi- i'm experiencing similar problem with my GTV (2003 TS). My windows, rear demister, front fogs, fuel lid and boot button have all decided to go on a break.
Would you be able to direct me to where N82 ECU is located and how you found the solution?
