GTV Rear screen demister fix.
60401 Views 234 Replies 72 Participants Last post by  HFStuart
5
GTV rear screen demister repair:
The problem with the early GTV’s rear screen demister is down to poor basic electrical design.
The power feed to the heater element travels along the full length of the car, from the fuse box under the driver’s side dash, along the dash to a connector behind the glove box, along the passenger sill, across the rear seat and up to the heater element, ironically just passing the ‘power source’ (battery).
This wire carries a high current load. Anything that carries a high current load gets hot.
The timer on the relay can fail and cause the heater to stay on.
When the heater stays on, the wire carrying the load heats up continuously.
This heat melts the flimsy plastic fuse holder and, in most cases, the plastic connector block behind the glove box.
Remedy:
The safest way to fix this, and ensure there will be no more problems in the future, is to remove the power from the wire running through the car, by fitting a power relay in the rear, close to the battery & heater element.
Note;
If the fuse box and / or connector under the glove box are damaged, it will need replacing first.
What you need:
• Single pole normally open 12V, 40A relay (£2.70, Maplin code NO2AW).
• Inline blade fuse holder (£1.50 from local auto parts centre).
• Bag of insulated spade connectors (£1.49, Maplin code JH82D).
• 6mm insulated round connectors
• AWG 10 or 12, (2.5mm Dia) wire, approx 0.5m
• Insulated crimp tool
• Solder & iron
• Self tapping screw
• Drill (suitable size for self tapping screw)
• 5A blade fuse
Installation;
1. Remove the boot trim section covering the battery and locate the wiring loom to the rear window.
2. Locate the Br/Wh wire in the loom.
3. Trial fit the relay in a suitable position (behind the right speaker, above the battery), and check there’s enough slack on the wire to enable you to connect to the relay prior to cutting the wire.
4. Cut the Br/Wh wire & wire up the relay as follows;
85 – earth - (switching coil)
86 – Br/Wh from front of car - (switching coil)
30 – Br/Wh to heater element - (power contact)
87 - +ve direct from batt (via 30A fuse) - (power contact)
I attached the fuse holder to the relay, by means of super glue, to keep it nice & compact, but as long as it cannot touch the chassis (earth), fit it anywhere between the battery & relay.
Drill a small hole where you want the relay to fit and attach it to the chassis using a self tapping screw. Secure the earth wire from pin 85 under that screw when fitting the relay.
Use 2.5mm wire for the power feed, crimp a round terminal to one end to attach to the battery +ve, (but DO NOT attach it until last thing), routing the wire neatly to the relay. Crimp a spade connector (or solder) the other end to attach to the fuse holder.
From the other end of the fuse holder, use a short piece of 2.5mm wire to connect to pin 87.
Crimp a spade connector to the heater element side of the Br/Wh wire & connect to pin 30.
Crimp a spade connector to the car side of the Br/Wh and connect that to pin 86.
You can now substitute the 30A fuse under the dash for a 5A fuse & fit the 30A in the fuse holder in the rear!
Last thing; connect the wire from the fuse holder to the battery +ve.
Job done! You have now turned the current loaded wire running through the car into a no current switching wire!
See less See more
  • Like
Reactions: 3
1 - 20 of 235 Posts
thanks, job for this weekend, weather permitting
Excellent post, well done that man :thumbs:
Very, very good explanation. Thank you. :thumbs:
so what happens to the existing heater relay?
Very well explined I think this I common fix that has or need to be done, were the alfa design fails is that the cable to the rear demister has not got the current carrying capacity of 30 amps or 20 amps on later models,
Thanks for this.It would explain the burning plastic smell when I turned switch to max the other day.
excellent write up, looks like ive got a fair bit of work to do this weekend now....lol
The existing heater relay still works in exactly the same way, but you have transfered the load from the wire running through the car to the short run of wire running from the battery to the new relay.
If you were designing it from scratch, you'd do it differently, but this is a sure fix that doesn't involve changing anything else :thumbs:
So the existing relay output voltage, that went to the element, now is used to switch the new relay. Therefore the long run of cable has a very small load on it and the high load is only on the short run from new relay to element. Have I got that right?
Spot on:)
what gauge wire did you use?
btw, it free delivery this weekend at maplins (from friday morning)
10 or 12 AWG should do the trick. They can carry over 40A, (thats 30% above rated, so quite safe enough).
Free delivery - no reason for anyone not to fix theres then :D :lol:
Wow, nice. Needed this, so tagging for near future :D
Please sticky!
just done this, nice and easy as luckly(?) previous owner had put a 20a fuse in, it had been completely fired but had saved the fusebox and rest of the wiring
took about an hour and a half, most difficult and time consuming thing was putting the fusebox cover back on, :mad: little plastic fasteners
This is what this site is all about. Stoyce, the word "legend" springs to mind.
I get the burning smell when its on for more than 5 min. I will be doing this asap. Will let you know how it goes.
I'm glad this is of use to others. :)
I've found some very useful information on this site, and it's only a pleasure to be able to offer some in return!
As for the rear window demister, I really don't like the idea of 'burning wires & plastic' in the car.
Safety first! :thumbs:
It is an excellent post. I am going to ask the Mods to make it a sticky as it is an importaint issue.
Good post :thumbs:
I tried using my heated screen for the first time a few weeks ago and noticed it wasn't working... looks like I'll be giving this a go shortly!
1 - 20 of 235 Posts
