Hi. I have a GTV Twin Spark 1997. Recently had a non starting problem where the immobiliser light on the dash went out as it should, but the injuection light then flickered off for a second before coming back on. The car then allowed the starter to turn but no hint of firing up. The problem was a poor connection (not blown) at the fuel pump relay fuse. This in under a plastic cover on the nearside part on the engine bulkhead. It is the far left fuse 7.5 amps sitting infront of the fuel pump relay, which is the far left relay. Pull out the relay and resite it, do the same with the fuse after checking it has not blown. Car may then fire up.
If your fuel injectors are "live" and the coils have power.. Crank sensor?
Ralf S.
