Has anyone changed the water pump in a 2.0 JTS GTV?
I've just done the cam belt and balance belt, replaced the water pump too, just started the car and it looks like it's leaking around the water pump, everything was clean when it went back together, but I noticed the old one has sealant around it.....
It was a genuine pump, didn't have a gasket, just the rubber O-ring.
I noticed when I removed the water pump bolts that one had coolant pouring out of the hole it was removed from.
I put liquid PTFE on the bolts when I re-assembled everything.
Just wondered if anyone had done one themselves and were there any tips?
Thanks in advance.
Thanks in advance.
