the mechanic i asked said it was a nightmare and would cost hundreds, im a fairly competant mechanic could i do it myself???
BTW, the gaskets don't normally go, its the manifold its self that cracks.
Bit of advice, get some paper and hold it near the joins, if it waves then there's your blow :thumbs:
yes I would say so, you would need to loosen the auxiliary belt and undo the air-con unit,
undo the nuts of the manifold and then the should then just pull off.
You will also need to undo it from the down pipe too :lol:
