1 - 15 of 15 Posts
Hello,
I have recently bought a GTV and unfortunately don't have an owners manual. Could any alfa owners out there help me with a dashboard query? Just above the oil light there is a symbol which has only just lit up and I don't know what it means. It is long in shape with sparks coming out at the end. Should I be worried? Any help appreciated..thanks, Sam Q.
Hi Sam Q, welcome to AO :)
Maybe the light is to tell you to light some fireworks to celebrate getting a GTV? ;)
Hello and Welcome !! :)
Post your problem in the GTV lounge dude and you get an answer there I'm sure !! ;)
Brera '08 JTDM SV
Sam,
Welcome aboard. It sounds like the injection system warning light. It normally comes on for a few seconds when you first start up so don't worry unless its lit up all the time. Do a search on the GTV section where you should find numerous related posts, including possible faults and how to re set.
Attached should be a PDF file of the idiot lights for post 98 cars in case its any use.
Thank you SO much for the pdf Neilly...yes you're right it is the injection fault symbol. Great help. Sam
Sam, I have GTV workshop manual on disc, tells you everything you need to know. With this you can strip your gtv down to nuts and bolts and rebuild. I can give you a copy if you like?
Hi Gazza,
You star, yes I'd love a copy of the manual...seems my car needs weekly attention to some thing or other- so a manual would really help. Sam
Sam, check your water level. I had an intermitant leak on my GTV, which made the injector light come on...
1 - 15 of 15 Posts
