Yes, that's what I found. My understanding is that with the Eibach springs being a stiffer than standard, more damping is required to manage the forces. So the higher setting will actually damp out the crashy/bumpy stuff and make the ride "better".I've tried this and you're right, it has helped! Less bouncy and crashy, so definitely better.
1/2 turn harder than fully soft - out of a total of about 2.5 turns to fully hard.
Are the rear Koni Sports adjustable? There's no mention of this on their website...
I had the same thought about the torque being too high when polybushed. I recently bought a second V6 with rose bushes all round (completely original setup), and the rear suspension goes up and down with my weight. On the other car (Powerflex'ed, Suplex springs, Koni Strt), it's rock solid with no movement at all with my (fly) weight. When you look at the poly bushes, there's a large radial surface area either in contact with big fat washers or the subframe itself. I'm at the point where the polybushed setup is going to get swapped out back to rose joints as the front is soft and the rear is too hard.I agree - but, the tightening torque you apply can greatly affect the movement of that polybush, you can effectively ‘lock out’ your suspension by applying too high a torque figure. It took me a while to realise that the service manual torque figure, designed for the standard metal rose joints etc, was just too high for my polybushes. I also think that rear subframes have different tolerances - and what may work for one car, does not necessarily apply to another.
You could check this movement by just pushing down on a rear corner?
I wouldn't want to start quoting different torque figures, grease sounds sensible. This will be the next job on the list when I get time, go back to rose joints all round and swap out the rear upper arms for new originals. I have spare springpans etc so I'll get those powder coated first. Pretty sure alfa workshop and eb spares sell the rose joints as well.I had the same thought about the torque being too high when polybushed. I recently bought a second V6 with rose bushes all round (completely original setup), and the rear suspension goes up and down with my weight. On the other car (Powerflex'ed, Suplex springs, Koni Strt), it's rock solid with no movement at all with my (fly) weight. When you look at the poly bushes, there's a large radial surface area either in contact with big fat washers or the subframe itself. I'm at the point where the polybushed setup is going to get swapped out back to rose joints as the front is soft and the rear is too hard.
So do you think it's just a case of taking 10-20% of the torque value off the bolt loads? And making sure the bush interfaces are all properly greased too?
Interesting... I have 2 V6 gtvs with identicle suspension rig. Koni sport front and rear on softest setting, standard rear springs and all rose jointed except the centre strut mount and the upper wishbone bushes and rear subframe braces. Alfaholics handling kit, - 20mm eibach springs on front standard front bushes and front strut brace. Both cars have 18 40 225 pirelli p0. One car ride and handling is sublime, the other is much more harsh..... I lowered the tyre pressures to 34 front and 36 rear which has helped but each gtv is very different.... 🍀
It would be interesting to back-off the torques of the rear upper wishbones/arms on the harsh GTV to feel if it becomes more compliant. Interesting also the standard rear spring vs eibach front spring combination, I've seen it the other way round on V6s before but that was likely for aesthetics rather than feel.Interesting... I have 2 V6 gtvs with identicle suspension rig. Koni sport front and rear on softest setting, standard rear springs and all rose jointed except the centre strut mount and the upper wishbone bushes and rear subframe braces. Alfaholics handling kit, - 20mm eibach springs on front standard front bushes and front strut brace. Both cars have 18 40 225 pirelli p0. One car ride and handling is sublime, the other is much more harsh..... I lowered the tyre pressures to 34 front and 36 rear which has helped but each gtv is very different.... 🍀
That's good advice, a quick drive around the block first to allow the suspension to settle before final torques applied.Btw, the original rubber bushings are locked in the subframe for sure: torque up the bolts when the weight of the car is on the suspension to lock the joint when the suspension arms are in "neutral" possition.
Mind if I ask how much the powder coating is as I am considering doing the same to my Gtv upgrades., I am about to strip the rear suspension on my GTV in order to get the parts all blasted and powder coated,
Good point. I tried various tyre pressures and 36 rear and 34 front seems to work....Why do you have higher tire pressure at the rear? The load on the rear wheels is about half of the front wheels.
With the original 205/50-16 pressure are 2,7 Bar front and 2,5 Bar rear.
With bigger wheels you can go a bit lower I guess. Maybe 2,3 or 2,5 Front and as low as 1,8 rear =>> Rear tire pressures are mostly given for maximum load which will never happen on a 916.
The harshness seems to come from front along with much lighter steering too, almost as if the tyres are totally over inflated at the front..... 🍀It would be interesting to back-off the torques of the rear upper wishbones/arms on the harsh GTV to feel if it becomes more compliant. Interesting also the standard rear spring vs eibach front spring combination, I've seen it the other way round on V6s before but that was likely for aesthetics rather than feel.
Hi Stu, not too sure of price yet as I will need to take all the components to the blaster/coater to get them priced accurately but he reckoned on budgeting around £350 for the dog legs, spring pans, upper wishbone, antiroll bar. That would be shot blasted, zinc primed and the powder coated. I started to pull apart the rear suspension last night but reckon it will be a few weeks before I have all the part off of the subframe. Once I get a firm price I will let you know. I am thinking of getting the sub-frame done as well, but as it is alloy wondering if I should paint it in situ ?Mind if I ask how much the powder coating is as I am considering doing the same to my Gtv upgrades.
