1 - 1 of 1 Posts
For the record: photo from engine side of the bulkhead and footwell side once the new pipe work and cylinder were installed. I pulled the pipe from the engine side once the cylinder was connected with a jubilee clip to pull the cylinder into position.
The idea that you can replace the cylinder rubbers with the cylinder in situ has to be nonsense because of the access problem and you wouldn't be able to clean the inside of the cylinder anyway, even if you managed to pull the piston out.
1 - 1 of 1 Posts
