1 - 10 of 10 Posts
hi guys my cars started playing me up. i get up in the mornings and my car allways starts first time i let her warm up a little before moving her out and parking her up then i turn her off for about 10mins before going back out to start her and go to work. some times she starts and then cuts out almost stright away. any ideas ?. i went out from work and she just turned over and never started this has neva happend before so i stopped turning her over then tried again and she started no problems
the plugs have not evan done 7k since changed, the engine runs as it allways has when running and ideas will be welcome
Tough to diagnose without seeing the car - could be lots of things. Fuel pump?
i had the same sort of problem with my 156 gta, ended up being taken to autolusso on the back of a lorry problem was a bad earth to the ecu but they also changed the cam and crank sensor and all has been fine.......not saying this is the problem like dodger says could be many things but hope this helps
1 - 10 of 10 Posts
