1 - 20 of 34 Posts
I was wondering how hard is to fit a gta throttle body to 2.0ts.I was thinking about custom intake manifold,gta throttle body,cold air intake,kn filter,ecu reprogramming and gta back box.
Will have 15hp more?Also what does it needs to fit the throttle body?
probaly need a adapter plate to make it fit,Why a GTA TB?,As i am pretty sure (certainly 2.5 v6,3.0 v6 engines)they are all the same?,if i am wrong?,please somebody correct me
You'll need to remove the cat or put in a high flow sports cat to make the exhaust flow better - without better exhaust flow - your intake mods will not help. Take the exhaust manifold off, weld up the outsides and open up the inside a bit:
http://www.alfaowner.com/Forum/attachment.php?attachmentid=198025&d=1377010943
Putting in a bigger TB mainly helps for bragging rights - if there are mismatches / steps in the path - it will rather deter than better performance - even if the step is bigger. Focus on trying to get airspeed / flow
I want to start from intake and then i will put a sport cat back.Can you give me the serial number of the adapter?I will probably open the inside and i will change the cat back,it costs about 300€ .
Problem is - Too big a TB slows down the flow of air. Too small and it restricts flow.
There is a lot of math based calculations for the correct size TB.
I upgraded my 1.6 to the 2.0. But I still believe its a little too large for the 138hp my engine kicks out.
One of my colleagues fitted a GTA throttlebody onto his 2.0 TS CF3. Because of the size of the adaptor it meant the battery had to be moved into the boot. I drove the car and it did feel strong for a 2 litre, but he had done other stuff as well like CF2 manifold & custom downpipe, no balance belt, no A/C etc. The entry to the plenum is narrower than the throttlebody so it meant using a cone to taper down from the throttlebody into the plenum. I don't think this is ideal, it would be better to start with a CF1 plenum and modify it to fit the GTA throttlebody. But then you'd lose the variable length inlet runners.
I will also change the cat back with a sport and and i will open the inside of the manifold.
So you are telling me to keep the same intake manifold and modify it in order to fit the TB?I will probably do this one,it sounds better.Also i will go for cams reprofilling.
Buy a GTA :D
You can't really modify your original inlet manifold, it is plastic.. If you get an inlet manifold from a CF1 2.0 TS then you could cut the flange off it and weld on the flange from a GTA inlet manifold so it matches the diameter of the throttlebody. It would save you making a long tapered adaptor and might mean you can fit the GTA throttlebody without moving the battery. But CF1 inlets manifolds don't have variable length runners so you might lose a bit of low revs torque.
I reckon GhostyDog's advice is better :D
I will probably take the CF1 2.0 intake manifold and gta's TB.Will i have any issues with the fitting or the ecu reprogramming?Also what else does it need to fit it except cf1 intake manifold and adapter plate?
You might need the 2.0 TS CF1 fuel rails and the base-plate for the cylinder head too.
For the TB alone: As long as your car has an Bosch electronic throttle (throttle by wire) it should work plug-and-play - the ECU manages fueling by the MAF and lambda for the most... To optimise - after you have done all your playing - then remap PROPERLY to get the best out of all. No need to remap for every step...
Fiat barrachta and panto hot have metal intakes which could be modified to fit a gta throttle body. But would require welding.
Discussion Starter #14 (Edited)
It wont be better if i buy a special custom intake manifold?Or its the same?
Can you send me a link with fiat's manifolds?
Does the Gtv 2.0 intake manifold fits?I've found a complete one with the injectors ec in good price.
What we are trying to say is that it won't fit a standard twin spark plenum. As its plastic.
You can't really weld anything to plastic to make a bracket to fit it.
So other options would be to find a plenum made from metal.
Now once you have a metal inlet you can fabricate custom parts to it.
I've a friend in Rotherham that did this to a fiat barrachetta inlet. Which is the same as the Fiat punto HGT engine. Based on the twinspark block.
So the inlets would match up for the ports.
Thing is the point I was making is that if you think its doing to improve air flow. It won't.
The 2.0L size is the optimum size already for 150-160hp.
Unless its kicking out 170hp+ you won't need a larger throttle body.
Discussion Starter #16
I read somewhere here that its possible to fit the gta's intake manifold
Is this true?I know gta's intake manifold has 6 holes but its possible to close 2 of them.Is this better or the fiat's intake manifold?
Is this true?I know gta's intake manifold has 6 holes but its possible to close 2 of them...
Are you serious..... :cheese:
Edit: just realised you probably mean the plenum chamber, rather than the intake manifold...
Discussion Starter #18
Yeah you are right,my english arent the best.Anyway,does it fit with some mods and how would it fit?i cant imagine
Yes I'm sure you could to that, but the amount of machining must be horrible - you need to get rid of 2 holes, they are not spaced right.... then you have to get mounting surfaces on the block :vomit:
Probably only the throttle mount surface and the "throat" that goes to the plenum chamber - cut that part off and weld it to a aluminum 2.0TS manifold...
Discussion Starter #20
I am not sure if this is right but i could make custom manifold that would fit on the recent mounting surfaces and plenum chamber's holes. I mean,i would use the gta's plenum chamber,tb and custom handmade manifold so i wouldnt have to open new mounting surfaces.
The only think i am not sure about is how i will close the holes and if i have to open the inside of block's intake holes and make new mounting surfaces.
Sorry for my english i hope you can understand me.
1 - 20 of 34 Posts
