1 - 14 of 14 Posts
Morning all,
As some may have seen, I'm trying to source some rear shocks for my car to return the suspension to normal! I've found a set on eBay removed from either a 147 or 156 GTA - with 57k on them. Would these fit my humdrum 1.9 JTD GT perchance? I assume they'll be a slight upgrade to the normal suspension, and I'll be chucking Eibach springs on them!
Many thanks!
Morning all,
Many thanks!
to what i know don't think they will.. your best bet is contact some breakers.. do a eBay search on alfa 147 salvage or breaking
Ah damn, there are certainly some normal shocks out there to be bought - just thought I could have a cheeky upgrade!
I see you've explored these avenues RC :biglaugh: going off the other thread, I'm getting some OEM shocks with Eibachs as planned!
So will any standard 147 & 156 rear shock absorber fit? Seems I've found a good set of new ones, they're advertised for 147 & 156 but no mention of the GT, probably as its been overlooked when listing I assume.
again to my research the 156 147 and GT run the same floor plan and when comes to suspension they fit the full range.. not sure what your budget is but they not best brand but it's 4 shocks and springs lower to 40mm for £155 delivered again not a well-known brand but for money I'm sure can't be any worse then what we have already.. im just going for the fronts but tge GT version as for some reason they are 50mm drop
You said it .. £155 buys you two quality REAR TRW shocks .. (front shocks are slightly cheaper)
Famous last words ... :paranoid:
Haha! OK yeah I've ordered my 156 rear shocks and some eibach springs. Now for the fun of fitment when they arrive...
GTA shocks WILL fit on any other 147, 156 or GT - the suspension is the same for ALL these cars, there was a slight difference in the rear spring mounts on GTs, but they still will fit. The ONLY other difference (apart from spring and damper rates) are that GTAs have different mounting pioints on the front uprights for the calipers due to the Brembos.
why the lack of faith.. your obviously one of these people who pay the world for the name!
You get what you pay for. 155 for 4 shocks and springs is too cheap to be good quality. I would only go for Oem or recognised brand Ie bilstein, eibach, koni. Last thing you want is to spend hours fitting them (or pay loads) only to find the ride is crap. If budget is ltd get an eibach pro Spring kit (100 alfisti) and get some GTA shocks.
I can indeed attest to the 'you get what you pay for' phrase, after fitting these coilovers :depressed:
totally agree what your saying
1 - 14 of 14 Posts
