1 - 2 of 2 Posts
Administrator
GT 2.0 JTS
147GTA
Electrics
Ecu repair
https://www.alfaowner.com/Forum/alfa-gta/375231-147gta-diy-ecu-repair.html
Paint
Engine
Fans staying on
https://www.alfaowner.com/Forum/alfa-gta/260430-fans-staying-temp-needle-0-then-you-most-likely-need.html
Gearbox
Suspension
Interior
Exterior
Lighting
ICE
Upgrades
156GTA
Electrics
Paint
Engine
Gearbox
https://www.alfaowner.com/Forum/alfa-gta/914818-gear-shift-adjustment.html
Suspension
How to tell if you have 330 or 305 calipers
https://www.alfaowner.com/Forum/alfa-gta/528497-how-to-tell-if-you-have-330s-or-305s-calipers.html
Interior
Exterior
Rust warning
https://www.alfaowner.com/Forum/alfa-gta/93876-156-gta-rust-epidemic-warning-6.html
Lighting
ICE
All Models
Check your top engine mount
https://www.alfaowner.com/Forum/alfa-gta/114801-check-your-top-engine-mount.html
Cambelt change
https://www.alfaowner.com/Forum/motoring-images/151859-how-2-5-3-0-and-3-2-cam-belt.html
305mm disc & Pad replacement (early 147 and 156 GTA only)
https://www.alfaowner.com/Forum/motoring-images/741361-guide-gta-305mm-disc-and-pad-replacement.html#post10761241
Upgrades
External links
Anti Roll Bar & Q2 Guide
http://forum.alfa156.net/forum/forum_posts.asp?TID=34357
V6 / GTA Gearbox teardown
http://forum.alfa156.net/forum/forum_posts.asp?TID=46086
Snapped Cam belt
http://forum.alfa156.net/forum/forum_posts.asp?TID=40552
Engine removal guide
http://forum.alfa156.net/forum/forum_posts.asp?TID=55454
3.0v6 teardown (Still relevant to 3.2 V6's)
http://forum.alfa156.net/forum/forum_posts.asp?TID=38091
Administrator
GT 2.0 JTS
Discussion Starter #2
New info links
Please post below links to threads you would like adding to this sticky.
If possible please indicate if it is for all models or specific to one.
1 - 2 of 2 Posts
