Morning all.
Yesterday I started my 2nd clutch replacement. Got from full assembled to fully disassembled in a little over 6 hours so quite chuffed.
Couple of questions related to some things I found:
The gearbox oil when drained had a metallic sheen to it and was very silvery. The oil in it has only done 75 miles and was replaced when I installed the quaiffe when I did the previous clutch job. Is this normal? My thoughts are it is new bearings from the quaife bedding in. Would it be worth replacing the oil again? I don't know what oil is in it but it came with the Diff from Dan at Autolusso.
The clutch fork/arm has about 3/4 of an inch of vertical travel. Is this normal? I cannot find any evidence of a missing circlip or retaining ring so I doubt there is anything missing.
Oh and finally. I am really tempted to leave the 3rd starter motor bolt off. Would it do any harm long term? It is no easier to remove the 2nd time round!
