Hi guys, just curious to find all the usual problematic areas from going through deepish water recently , running very spluttery . Could it be water in the plugs ?
possible lamba sensor plugs have water in them or any connectors around gearbox area in the past I have had to pull the sheafes back on the various connectors and dry them out.
Ah, that sounds a hood idea, I'll get them
Up
On ramps asap, thanks , clutching @ straws here, air filter clean& dry anyway!!, maf appears ok. That's the next port of call , lambda
Just hope the cylinder hasn't sucked up any water and bent a few valves up.
Check the basics as you are doing and if things persist, get a compression check done etc.
4,5,6 plugs & coil packs fine(easy ones) still misfiring, all exhaust leads etc are all intact , gave everything a proper squirt with a wd40 type spray, as much as could be done, idling bait better, but still misfiring big style . And running like a buggered v6 should be really , booking it in at a Indy diagnostic check to see if we can get a more descriptive result other than ' random misfire' !!!!
