1 - 11 of 11 Posts
Hi guys does anyone know if its possible to stop the GT widows from whistling as my passenger one has just started to whistle ,i do coat the seals with silicon to aid the glide but cannot seem to stop it whistling . many thnx ......Mark
+1... above 60 its getting noisy!
I belive from what ive read its very common but im still not convinced what can be done to fix it properly.
I'll have a go at that then.... by moving the catch plate on the body then I take it
Thanks for the tip. Will check it out.
Move the catch plate in about 2mm. You'll need a torx bit to undo it though. I didn't have a whistling, but there was too much noise getting in somewhere, especially when driving past walls. Shifting the catch plate seems to have done the trick.
1 - 11 of 11 Posts
