Morning All ,
In the last day or 2 when my GT is driven from cold there appears to by a creak noise from the suspension ,after a few miles it disappears - I reckon it may be a bush , whatever it is appears to be temperature sensitive : I recall seeing a post re this a while ago , but after a trawl through can't locate it , can anyone help ?
thanks
Might have been me. When my GT was new, it used to make a creaking noise from the front over speed humps. It seemed to come and go for a while, and then just went, never to be heard again.
Most suspension noises on the 147/156/GT are caused by the bushes being knackered. If you've done at least 30k miles, then that would be the most likely cause. Another is the anti-roll bar drop links.
Banned
Its a factory standard option I think you will find - and not necessarily anything worn out - its there to let you know when it's cold outside ;)
But do keep an eye on it and if it creaks in the warm weather or contiuously then you have a problem.
Chris
Thanks guys - it has just passed an mot with no advisories - so I think you are right , somecars have a light on the dash to tell you its cold the GT makes a noise !:)
My front is really squeaky going on 4 years later, but only on speed bumps and the like, and I can still throw it into bends faster than seems sane, so I am guessing its all working right up front!
