Hi Newbee here
I have a problems with a friends Alfa GT JTD 2005 that's causing some headaches, I've searched the forums and cant find the answers I need so starting a new thread.
the issue started with the windows. while in the a garage the windows were dropped and the battery disconnected. When the guys working on the car reconnected the battery the windows wouldn't roll up, so they removed the door panel and "hot wired" the windows to get them up. Now she is left with the following problems.
windows not working: when the window rocker switch is pressed there is a beep but noting else, I cant here any relays clicking, so from that I would say that power is getting to
the switch but not the regulator.
Boot Release not working: when you press the key fob button the indicators flash, but that's all, no servo sound, no relay click, I can open the boot manual with the red pull cord but that's all.
Fuel Filler Flap not opening: Again like the boot the switch will not do anything, the flap can be opened with the red pull cord.
I find it odd that all these things have gone at the same time and my first thought was a fuse, so I had a look in the owners manual and found fuse 60 operates the boot. I eventual found it tucked up behind the dash on the drivers side, only confusion is there are 6 fuse spaces but only 4 are used, and only 4 mentioned in the book but I assume I have the right one, all fuses in that small block are fine.
At this point I have drawn a blank, with out a workshop manual I cant see what relays control what systems, or what else could be causing this.
Any help would be gratefully received.
