Hi guys, Ive found a set of 8c replica wheels for sale,18 inch, i have asked the seller for the pcd, all that the advert had was The spec size on the rim is 8JX18H2-41
will they fit on an 05 1.9jtd GT?
GT is 5x98mm PCD.
Same as 156/147/GTV/Spider.
I don't think an 8" wide ET41 rim will fit straight on without spacers either. I could be wrong though.
Tyres would be 225/40R18
thanks.. waiting on the pcd from the seller.. I dont mind having to fit spacers though
agreed, that a spacer would be ideal if the offset is +41mm. mostly for cosmetics and track width. for your reference, the GT 18" multispokes are also 18x8" but with an offset of +32mm. so you may want a 10mm spacer (presuming you can't get 9mm !). but an offset of up to +35mm would be fine too.
The seller said the pcd is 5X98, which is apparently the same for all Alfa's
159/Brera are 5x110
166 is 5x108
Mito I think is 4x100
So not ALL are 5x98
Anyway, if they are 5x98mm PCD and have a 58.1mm centrebore, then they will fit. But I still think they will need a spacer.
