Seem to have a problem with my Reversing sensors when i out car in reverse i get the beep telling me it has activated then a 5sec constant tone,so today i sat in the car engine running with the car in reverse gear i got one of the guys from work to put his finger over each of the sensors only 1 of the four worked ,any help would be appriecated i am going to phone the garage where i bought the car to see if its covered under the 3 month warranty i got but i think it`s just a basic warranty as i opted out of purchasing a 12 month one.
with mine ....that eventually broke ....after the long beeeeeeep you usually get a short beep, which tells you which sensor is bust. So long beeeep, then 2 short beeps tells you sensor 2 is knackered.
Mine kept getting moisture in the wiring and just rotted away and probably fused something. I bet its the cold weather causing you issues.
Mines very odd too, sometimes works and sometimes doesn't. I get the beep on engaging reverse, it let's me know it's working.
I gotta get round to checking the wiring out on it. Just too damn lazy
Did you get it fixed ? There are a lot of wires and connectors hide behind the bumper to connect these 4 sensors ....
