Hello :) I'm new to your forum and can not get by with the best English language .. If I missed some rules let new members send me some :)
Thus I present my problem for which you are all mostly heard ..I have a Misfire cyl. 2 and occasionally on CIL. 4 ..
I did:
- Clean injectors-
Checked coil pack / ok
- Spark / ok
- Compression ok
- All refreshed and jacks with contact spray
I have no more idea what it could be .. Please help.. :cry:
Had to have injector 2 replaced on mine last year. Been good as gold ever since:thumbs:
I took off the injectors changed their places. On the first cylinder placed on the cylinder number two, but again appears Misfire cil.2. Is that my ecu can make trouble?
I became desperate, I really like this car ..
Can be caused by a number of things but Lambda (o2) sensor and coil packs most common on jts, don`t delay in getting it fixed or you can end up needing a new cat aswell :(
Coil packs and lambda is ok :) l do not have a catalyst on the car, removed because it was clogged.
