I have raised before, but does anyone else have or has had the same problem? brake pedal noise & pedal juddering, actual brakes appear to work ok? Its not just the noise but the pedal is hard to be pressed smoothly, its uneven on applying pressure. Been ages, Alfa not come up with an answer but told it is a common problem also with 147s. Well how common? I cannot see similar threads on here. Also any offers?
sounds like warped discs... did you try new disc already ?
Just in case anyone has an idea, the pedal without the car started is firm(expected as no servo) but smooth. Only when the car is started & not evenh moving is the pedal noisy & juddery, by pumping the brakes the pedal is OK for a couple of presses then as bad as ever. ABS thought is interesting.
