Can anyone tell me the torque setting for the rear hub nut. ELearn just seems to have the front ones. Cheers
Found it - Bloody hell that's tight - Not sure how your supposed to measure that tbh.
Tightening torque GT rear Hub nut 300 -330 Nm
An expensive torque wrench does the trick.
But if you take the middle figure, that makes 236lbft in old money, so 78lb on the end of a 3ft breaker bar (assuming no flex) will give you the torque required.
Apply 33kg to the end of a horizontal 1 meter long bar attached to the socket. Or some other combination of weight and lever length that adds up to the same torque. Could also buy one of those cheap electronic load cell hand weighing scales and use that to apply the "weight". Surprisingly accurate even at high kgs.
