Hi all. I have a bit of a quandary here.
My Jtd gt has a leak at the connection to the clutch slave cylinder, where the hydraulic pipe meets the slave cylinder.
Has anyone else experienced leaking from this area? I`m not sure if I need a new cylinder or a new pipe.
my guess would be the pipe, never heard of one leaking there, its not a place what is prone to corrosion, a good clean up should show for sure, cannot see the pipe coming slack either as its clamped to the gearbox, i assume it is clamped? check that or it may have got a crack due to vibration, should be a clamp where the matal turns to rubber roughly under the cluch arm
Mine had a leak there. I was leaving fluid everywhere. They get old and brittle. As soon as they move they split. I found my split. Could see it. Inspect the hose 1st. U may need to remove the battery holder too see it better. I did. A new hose is about $150 au. Don't know what it works out to be in £. I put it in and bled the system. Works like a treat.
