I have a gt jtd it has recently started to lose power low down and takes some time for the turbo to kick in i removed the egr valve which was clean sprayed it with wd40 and refitted but still lacks power any ideas?
did the solenoid move.....that as to move freely....there is a pin it pushes out to open the valve
there is also the map sensor its just along to the left of egr held with one torx bolt......it pulls out gently.....brake cleaner cleans it nicely
id do a ecu reset too to let ecu know things have changed....or u may not see a difference
sticking egr normaly leaves a smoke screen when u set off.......no harm in cleaning both
