Hi, I have been getting somewhat erratic running from my JTD for a while, plugging in ECUscan seemed to point to the MAF (duly replaced) but I am still getting a difference in the demanded air quantity and the actual which then suggests an air leak somewhere. (EGR blanked off with a plate with a hole and no swirl flaps).
Both main hoses are silicone and are good, I did find a twist in the vacuum pipe connector, and that improved performance now end but there are now times when it will not rev up then burst into life after a minute or so typically after being stuck in traffic or after hitting a bump. I went to investigate air leaks and found air being forced out of the air intake box through a pre-formed hole in the base, I am guessing this hole should be plugged somehow......?
Would this be the cause of my issues? And if not, any ideas where else to look.
