1 - 11 of 11 Posts
Hi guys, hopefully someone can help ...
I've read a few of the threads on faulty fuel flap release issues but need to know which fuse relay relates to it - the handbook doesn't give any indication which is frustrating . I've checked power to the switch which is fine, there's no power at the solenoid end after checking with multimeter.....does anyone know which fuse and relay it is?
I don't get the sound of the relay switching as it used to when it worked , so I'm really hoping it's something as simple as nice and simple as that.
Thanks in advance !
Lloydy :)
Hi there, I am looking for the same relay. I can see four relays in the fusebox under the steering wheel, but I don’t know what’s what...
Does anyone perhaps have an overview of all relays? Can’t find it in the instruction manual. Many thanks.
Many thanks. However, it only states the location of the fuses while I am trying to find out the location of the fuel flap relay.
Under the dashboard I can see four relays: two black ones and two red in the middle. Should it be one of those? Or am I missing something?
After short google inspection - there is no relay for fuel flap.
Can you give more info about your problem with flap?
maybe this will help:
The relay is supposed to be located on the "supplementary fuse box", I think behind the "standard" interior one ....
I can only see the cover, it says 1 from 5. Can you perhaps post the other pages as well? Or send it otherwise to me?
In the meantime I am trying to take out the fusebox, but I don’t have a clue how to. For example, I don’t even know how to remove the connector wit the purple clip...
Many thanks!
Fortunately, no need to take out the fusebox. The relay ‘floats’ behind the box, together with another relay.
You can access it by removing a panel, which is secured by only one bolt under the fusebox.
Does anyone know a part number or something so I can try to order a new one somewhere?
On 1st picture,that 2 big fuse,one of that 2 is this from last photo?
No, 1st picture is the regular fusebox under the dashboard. The brown one is behind that fusebox and sits together with a black one. You can find it if you put your head upside down under the dashboard. Removing a small panel and a lamp will help finding it.
1 - 11 of 11 Posts
