Hi guys
I purchased a fascia to surround my new single din head unit however it doesn't seem to "fit" properly and pops out every now and then.
What would you recommend I use to stick it down ?
Sent from my HTC One M9 using Tapatalk
interested to see the responses here.
i had a GTV and had the same problem.
My 147 needs one and I will hopefully put the replies to good use.
I have some double sided black foam tape, may just consider using this......
D
I had the same problem when i installed a double din, its the slots on the upper part of the dash, i just played around with them till the lugs of the fascia clicked in.
As opposed to gluing it in place why not try working out why it isnt fitting properly, my double din unit just need a little filing before fitting.
If you read the OP, it's a single DIN!
