I have a 2006 GT, the driver's window doesn't go down when pressed but when the door is open and the glass drops down a few inches the glass goes up when pressed. So it appears the window works going up but not down however I ain't been able to check this with the window being fully down.
I've tried the soft reset several times but hasn't worked. Is there anything else I can check/try.
