1 - 12 of 12 Posts
Hi guys,
I need to check a few fuses in the box as some bits arn't working on the newly put together GT.
But when i open the hatch to get at the fuses/relays there is no diagram in there that says which each one does?!?!
Is this normal? In the flap is a concealed part which might have held a piece of paper showing what each one is for.
If this is the case can someone take me a picture of this? Or scan it from the manual etc?
Really appreciate it, thanks!
Discussion Starter #2
Anyone have a look in their fusebox cover and see if there is a diagram? Really need this as my headlights and wipers wont work :(
Andy, there should be diagrams in your owners manual for this - probably near the section which describes the bulb types for front, rear & interior lighting.
Hopefully I'll get my Bella back tomorrow so I'll have a look in the manual and get back to you unless someone else resolves your problem.
Cheers guys, i dont have the manual atm (its on back order at the stealers :( ) So i'm counting on you guys :) Thanks
Ok, page 207/208 (rev. 09/2006) of my manual states the following:
Dipped headlights are off the fuse box on the dash (Fuse F12/F13). These are the last two fuses on the bottom (5th) row, closest the series of relays.
Main headlights are off the fuse box near the battery (Fuse F14/F15). These are the 1st & 3rd fuses to the right hand side (row of small fuses bordered by relays)
Its not very clear about the wipers, just mentions the washer jets.
I have no access to a scanner at the minute. I will take my manual up to my parents place and do it there for you over the weekend if it helps.
I'll try to get my hands in one, this afternoon. If possible... I'll send it to you.
Hi Andy,
If you ever got that fuse box diagram for the GT, any chance you could send it on? Im also having a problem and dont have a manual, so that would very useful!
Cheers,
Adrian
1 - 12 of 12 Posts
