1 - 1 of 1 Posts
Just replaced the driver's side door handle. Big thanks to Pubsinger for his excellent step by step guide :thumbs:
I managed it without removing the window so it can be done that way. My flex head ratchet spanner helped!
One bit of info to add is that the lock just pushes into the new handle - I used the key to push it into place. There is no need to remove the screws from the handle.
I also found it easier to attach both wire links to the handle and feed them into the door together as I doubt if I would have managed to connect the top with the glass in the way.
I had taken the easy option of buying an inside handle plug with the new outside handle - the dealer did not stock the top plug and needless to say it snapped - despite using fine nose pliers to try to squeeze the two parts together!
1 - 1 of 1 Posts
