The other days I was driving down a lane and hit a pot hole, HARD. No damage, but the airbag warning light came on. I stopped, waited and re-started and it went out after about 10 seconds. Anyone have any ideas?
Should I be worried?
DK
i wouldnt but im not a mech.. if the light is out the air bags should be functioning correctly... probably an alfism.
The GT has an issue sometimes with a dodgy connector under the driver's seat. the same occaisionally happens if you move the seat whilst driving. The bang probably caused the connector to bounce around for a second, causing it to throw a wobbly.
Shouldn't worry about it.
You could always pop along to the dealer and he'll charge you an hours labour to..
.. well, he'll find something to charge you for, mine fitted a tie wrap :p
Cheers guys.
Just wanted piece of mind really. I will get it checked at the next service.
Mine came on yesterday. I will check the connectors under the passenger seat and see what happens. I have also read on various threads that the airbags are disabled if thats the true cause. A dodgy back bulb ... hmmmm not sure as it seems to be a common occurence. I have read £30 to reset it.
AB light on = AB out !
