They look the same....is it the connector that is diff?Look to be different, I'm afraid...part numbers 156071739 for GT, 156071747 for the 147.....
Yes!That's all i need.The top part only.However if it is just the plastic switch part that is broken you can swap the 147 switch onto the gt electrics (just clips on) just make sure you don't loose the little grey pegs inside. I did this with a 147 switch and it works perfect. Added bonus is that the ecu won't throw any errors either![]()
If the problem are broken switches for lifting the windows you can have these made with a 3d printer. A friend went to someone who makes such prints and now he has their exact copiesJust replaced the passenger's switch(the whole unit) with a 147 used one and ...bingo!It works![]()
