My 2007 GT 1.9 JTD suddenly won't start. It turned over a few times and the engine 'almost' kicked in. With the accelerator pushed down, there was a lot of vibration but it didn't catch. Without the accelerator pressed down, it just turns over.
The battery seems fine: the lights were on (bad practice perhaps, yes) and work fine now. No diagnostic messages showing on the dash.
Now, even with the accelerator down, it just turns over but the engine doesn't fire up.
The car had been on the flat, level drive for 24 hours without moving. It's quite cold...6 degrees or so.
Background
Done 94k miles or so. This Alfa has had a few problems recently. I added (again maybe stupidly, but a friend recommended it) some injector cleaner into the fuel tank (it was 75% full) and within 2 minutes, I had lost all acceleration. It turned out that the turbo was jammed solid. It was reconditioned and refitted and for a week the car ran perfectly. Everyone has said that it was **probably** pure coincidence that the turbo jammed after adding the cleaner. I have since topped up the tank twice to dilute it as much as possible.
I have noticed that the car was taking a fraction longer to start up each morning than normal. Maybe an extra second before firing up.
As you can tell, I'm really not at all technical. I really enjoy driving my Alfa but it's starting to become expensive. I do hope someone has some ideas. I have seen quite a few posts in this and other forums but there seems to be almost too much information!
Background
