1 - 15 of 15 Posts
Hi All
I have a groaning suspension (Front, passenger side) for approximately 7 months now. I have been to 3 garages to have it fixed and have had the following done:
- Anti roll bar
- n/s/f upper suspension arm
- n/s/f antiroll bar link
- o/s/f upper wishbone and anti roll bar link
- n/s/f upper suspension arm (for the second time)
It is getting pretty frustrating now. It only happens when it is warm outside (13 degrees + but is really loud). I don't know if it is relevant but it all started very soon after I had the AA out to sort a dislodged fuel pipe and they jacked the car up (rear drivers side).
If anyone has any ideas as to what it could be that would be appreciated.
Alex
lower wishbone?
typically:
squeak = upper wishbone bushes
knock = ball joints of wishbones [upper or lower], drop links.
a thumping sound, low down at your feet = arb bushes
a groaning sound = excessively worn bushes or loose bolts.
each lower wishbone has 4 bolt to hold it in place, some of these could be loose or 'threaded' OR your wheel bolts could be loose, i doubt they groan for 7 months though
mine was a lower wishbone - unfortunately one of the last things I changed ! :rolleyes: but the other components were worn
yep, if you tell yourself that enough times it starts to sound like 'the truth' ;)
If it a lower wishbone is it easy to identify. I am amazed that 3 different garages have not been able to pinpoint the problem?
How can I tell if it is the shock absorber?
as another poster said it could be a broken spring, my friend V6Jon had a creaking noise form his car, turned out the lowest coil of a front spring had broken.
measure the height of the highest point of the wheel arch to the ground, on a flat surface. all 4 corners ahould be within 10mm of each other
almost as bad as Rob£rtos
Have measured distance from top of wheel arch to floor and all distances are the same. Guess this rules out a cracked spring? Any other ideas?
In my case I pinpointed the noise to come from the lower wishbone outer bush (the one below the outer CV joint). I had someone jack the car up and down while I listened through a swimming pool hose, with the other end stuck against the various bushes and ball joints (I suppose a vacuum cleaner hose would also work).
I then removed the wheel and inspected the bush. It was clear that the bush is disintegrating, with about 20% of the rubber already fallen out (the bush is only the front halve to start off with).
Discussion Starter #15
Can anyone post a picture showing the bush that DawieS is refering to?? I don't have a clue!
1 - 15 of 15 Posts
