So when I had the 159 I had a few failures on it, now 2 month in I have had my first failure on my Brera. To be expected when you own an Alfa Romeo I hear you say.
So what has failed?
To start with on the 159 there was:
Bosch ECU - German
Bosch high pressure fuel pump - German
The clutch and DMF flywheel failed - Sachs? Err German
Now on the Brera:
Eibach front coil spring broken - German (again)
For balance, I did have two drive shafts changed on the 159 knowing nothing otherwise I'll assume they were Italian.
Maybe a few more bits of our Alfa Romeos should be Italian, judging by my experience could make more reliable cars!
So what has failed?
Bosch ECU - German
Now on the Brera:
