1 - 9 of 9 Posts
2017 Guila 2.0 Tbi Lusso spec, 1972 S2 Spider Junior, wife drives 939 Spider, + Abarth 595
The other weekend the wifes cousin was down from Yorkshire, she has a 1.4 Golf, about 09 plate. She is the type of person who considers a car as a box with 4 wheels which gets you from A-B and makes a good mobile rubbish tip. I commented on the oil bottle she had in the passenger door pocket. It turns out that she has to regularly top the oil up, which she did before leaving home. I thought it was worth checking before she left for the return trip, there was not even any oil to mark the dip stick, I put in 1 litre! It is of course questionable whether the oil had previously been topped up correctly, but for a car with only 77K on the clock any consumption is suspicious. I was reminded of this consumption yesterday when following a 1.4 Polo, trailing tell tale blue smoke.
Do any of you VW fans out there know if this is a weakness on VW engines? Oil consumption is something from the past I thought (TS engines)
Huge number of threads out there on VAG group car oil consumption.
I had a 2004 Audi A4 convertible from new and it used 1L of oil every 5-6k miles. Apparently all within spec for VAG.
Never saw any blue smoke so never was sure where it went....
Have a look on Pistonheads under VAG oil consumption
:wow:
No mention of this when the advertising tells folks how brilliant cars they are.
Had a 1.4 polo for years. I have to say that apart from a lambda sensor light that always came back on within 3 minutes of being reset by the VAG garage I used to get it serviced, it was pretty reliable. Not particularly well made, thin metal, horrid plastics in the interior but durable seating cloth at least. It certainly did drink a lot of oil though.
Yes, I had a new 1.8 A4 back in '96 and it was not dissimilar to yours over several years' ownership, maybe a bit worse towards the end. Hellishly wasteful and expensive though.
I owned Audi's back in the late 70's early 80's and I never remember them using any oil.
My Golf V5 20V didn't need any topping up between changes, in fact the level on the dipstick barely moved.
I know some of the 4 cylinder engines can be rather oil thirsty though.
Someone I work with has an 08 plate Skoda superb with a 2.0 8 valve engine and he said he is always having to top the oil up.
My T/Spark (1.8) only weeps oil at the rocker cover... otherwise it doesn't lose any oil at all. I put in less than half a litre between 12,000 miles services. :thumbs:
Ralf S.
:wow:
To be fair, it doesn't seem like they are broken at all.... they just seem to use oil. Its a cost consideration of sorts, but although my A4 used to like a slurp of oil it was utterly reliable and never cost me much to service. I owned it from new til it was around 5 years old and we only sold it due to too many kids otherwise it was a great motor.
1 - 9 of 9 Posts
