1 - 9 of 9 Posts
Morning does anyone know where the glowplug relay is located on a Alfa 156 1.9jtd 16v (150). Thanks:smoker:
Should be a black cover next to battery in the engine bay look under the cover everything is in there there is a diagram on top of the cover showing what is located where hope this helps
However the location of the relays may not have any relation to the diagram on the cover ;)
If there is a recorded code against it ('the module') or the warning light is on, it is often the glow plugs and not the relay itself which need replacing.
Thanks alot Chaps, i have already changed the glowies, changed the fuse on top of the battery cover, now that i have finally located the glow plug relay, i will be ordering the part asap. The code which exists is p0670 - Glowplug circuit malfunction.
UPDATE: The following above has fixed the P0670: Glow plug circuit fault, thanks alot guys :thumbup::thumbup::thumbup:
1 - 9 of 9 Posts
