1 - 11 of 11 Posts
Hi, I'm not sure if this is the right place to post this, but I'm pretty happy with what I've done and maybe it can help others.
When I got my Giulietta a couple of weeks back, the little glovebox on the top of the dash wouldn't close. It turned out that the little arrowhead shape had broken off the lid and so it couldn't engage the latch anymore.
I modelled a little arrowhead and printed it. I then put it into the latch put some superglue on the base of it and closed the glovebox for a couple of minutes while the glue set. It works now which is excellent.
I can't seem to be able to upload the files but have the solidworks format and stl format so here it is on Grabcad.
If this is the wrong place to post this, then mods please remove it.
postage from South Africa might be a bit expensive
Discussion Starter · #7 ·
Hi... this is my simply fix for the top broken part... easy adjust height with screwdriver...
Regards... ;-)
1 - 11 of 11 Posts
