Late 2002 147 Lusso with twin/dual climate control.
Should this have a pollen filter and if yes, where do I find it??:confused:
If it's the same as a 156 (which i'm pretty sure it is) Under the plastic ribbed scuttle plate at the bottom of the windscreen. Open the bonnet and remove the foam from the NSR corner of the engine bay above the suspension turret. Remove the rubber sealer that runs along the edge of the rear engine bay and remove the passenger side plastic cover with a torx bit, its under that m8. You shouldnt have to remove the wiper arms, they are for the drivers side... ;)
Access is from the passenger footwell, near the bulkhead, but behind the glovebox. Nightmare to get to. Do a search on this forum...you'll find pictures too. When the car is first built the pollen filter is a one-piece part, but the replacements are in two halves as access is so awkward.
I took my pollen filter out and have not replaced it.
