Administrator
GT 2.0 JTS
Paint
Paint code/spec for the dark grey Turbine wheels is 693/B, Grigio Anthracite Diamonte
Electrics
Engine
Specific failure of the MA unit on 1.4 engines. The thread also highlights:
1) Requirement to run specific diagnostic to determine MA unit failure, rather than removing the cylinder head.
2) Current goodwill payments provided by Alfa UK toward cost of replacement, even though the car may be out of warranty.
https://www.alfaowner.com/Forum/alfa-giulietta/734577-suspected-broken-valve-at-33k.html
https://www.alfaowner.com/Forum/alfa-giulietta/784098-how-to-multiair-unit-replacement.html
Gearbox
Recently changed the gear position lever sensor. Turned out to be two broken wires. It should be possible to repair the wires in situ as from what I can see the sensor is based on the Hall effect and a sloping metal strip and therefore needs calibrating if disturbed. The new one (£66) comes with a locking clip that's removed once in position. Number for the sensor is 0055228312-001. I suspect the -001 indicates a modified version.
Air Conditioning
Steering
Suspension
https://www.alfaowner.com/Forum/alfa-giulietta/683274-the-definitive-squeaking-knocking-front-suspension-thread.html
Brakes
Interior
Door handle replacement, Alfa Romeo now possibly covering outside warranty under goodwill claim, see below:
https://www.alfaowner.com/Forum/alfa-giulietta/1169455-giulietta-car-door-handles-snapping-issue.html
https://www.alfaowner.com/Forum/alfa-giulietta/253361-giulietta-interior-door-handle.html
Exterior
https://www.alfaowner.com/Forum/alfa-giulietta/608585-how-to-giulietta-aerial-base-replacement.html
Original Ersatzteile - genuine parts GmbH In English: Original Ersatzteile - genuine parts GmbH
The linked supplier is able to supply the repair kits (SenCom) for both sides of the hatch. Cost: €150 including VAT and postage (the pair). I have ordered mine for when, not if, I need them. Were available from a different supplier on eBay and Amazon, but no longer. Includes connectors and rubber trunking.
Part numbers are: SenCom 503015 and 503016. Available individually.
Genuine kit from Alfa dealers is about £400 on eBay.
Brand SENCOM: Reparatursatz für Kabelbaum
***See picture below***
Lighting
Headlights from rhd to lhd
https://www.alfaowner.com/Forum/alfa-giulietta/359583-giulietta-head-lights-rhd-to-lhd.html
Upgrades
External Links
Owners manual
http://aftersales.fiat.com/elum/Model.aspx?brand_code=83&id_language=2&id_model=ece27544-f724-4f7e-8938-85989ab697d6&market_code=EN_EU&cat=lib&part_number=#1
Spares Eper
Fiat Eper link
http://ricambi.l-automobile.com:7080/navi?GUI_LANG=3&LANGUAGE=3&COUNTRY=12&WINDOW_ID=1&KEY=HOME&EPER_CAT=SP&MAKE=R&SBMK=R
Elearn download link
Servicing guides
Administrator
GT 2.0 JTS
Discussion Starter #2 (Edited)
New info links
Please post below links to threads you would like adding to this sticky.
If possible please indicate if it is for all versions or specific to one.
Remember.
Post in the main forum then copy the link here.
Well I have done a bit of looking and found that the handle is made/distributed by Miraglio in Italy. Their part number is 60/181 and AR {whole panel I think} is 156092165 (for right hand side). There are two on eBay from the same supplier in Italy but are not cheap! (http://www.ebay.co.uk/itm/Handle-door-opener-internal-front-right-Alfa-Romeo-Giulietta-Adattbile-/252674341253?hash=item3ad4907985). The Miraglio site also shows how to change the handle and this is the link:-
http://www.miraglio.it
Hi, I think this sensor is going to be on my to do list..........what's involved in changing it???
Quite straightforward:-
Access to the gear lever from top, gaiter moved out of the way. From underneath exhaust pipe unclamped (and hanger released) and moved to the side to gain access to a plastic box and to remove a heat shield, on mine that used pop-rivets in two places and were removed by drilling the heads off. Most difficult bit is threading wires back and that's not really difficult, just awkward. Ensure gear lever is in neutral position. The black clip portion of the slider (that's shown at the bottom sticking out to the left) can only go in one place then the yellow clip slides in. Pull the red retaining clip out of the way once sensor is definitely in place.
Here’s a list of the wires on either tailgate wiring loom:
Right Loom
F036 right light in hatch (Tail, brake, reverse, fog light)
N016 Rear wiper
P025 Power supply antenna
P055 demister
Antennae
Left Loom
F040 Third brake light
F035 left rear light hatch (Tail, brake, reverse, fog light)
N057 motor lock tailgate
I033 switch to external trunk handle
P055 demister
Washer pipe
