Hi everyone, new to the forum and looking for some advice on my 2012 regd Guilietta 2.0 Veloce 140 bhp.
Engine management light on and no stop/start, no DNA, no cruise control when loss of power occurs and car struggles to get above 3200 rpm,
Had in into an Alfa Service Dealer here in Ireland and they diagnosed an a faulty air mass meter which was replaced and problem still persists, They said they checked the wiring to air mass meter and egr valve etc. I bought a secondhand EGR valve and had it fitted but problem is still there. Could still be the egr valve!
Some history: I bought the car in the UK with 100k miles with suspected top engine noise so was hoping to get away with replacing cam followers and cams, turned out it was a crank bearing so I replaced the engine with one from a breakers yard with 28k miles on it, had a guy fit the engine and engine management light came on within 2 days of collecting the car, he could not find any fault so I took it to an authorised Alfa service dealer who diagnosed the air mass meter as described above. Took it to another independent dealer who said it was still showing up an air mass fault. Code 10FH/271. Any suggestion as to what I should try next as I have quite a bit spent on trying to solve this issue without any success to date. When the car is going well it is fab to drive especailly in Dynamic Mode so am hoping some one of you guys may be able to help?
