Hey guys, so I decided to remove the fixed intake swirl flaps on my giulietta prior to getting it remapped. It has been mentioned in a few posts before but I thought I would share this experience with you.
Ok this was quite difficult ( I'm a vehicle mechanic of 21 years), the high pressure pump does need removing as do the mounting studs. Two 6mm threaded bolts will hold the sprocket so the timing belt isn't affected. Coolant must be drain early on to avoid flooding the inlet ports. The dpf pressure sensor pipes run very close to the intake manifold and this makes the removal very very tight. Although there is little room to get in everything else at bolted to the manifold really just needs removing and kept in some order.
The size of the actual restriction in the manifold isnt that big but obviously I removed them anyway. What I did notice was the size of the pipe from the egr valve entering into the intake manifold (very large, I haven't seen one this restrictive before) so I fitted an egr blanking plate with 8mm hole and then modified the pipe to remove the prutrution into the intake manifold.
I have no power figures yet but there is a definite increase in power, it revs freely and pulls harder through the higher revs. I haven't noticed a drop in low/mid range torque in fact it feels stronger.
I will be interested to see what hp I will see before and after remap.
