All sounds normal. What you are hearing at startup is the high pressure fuel pump if it is more from the driver's side.
Thanks metalgod, sorry meant to reply sooner. The noise is a tap, in time with the engine tick over. The car drives fine, the engine pulls fine. My old Nissan used to tap on start up, and there was a rattle upon the first touch of the accelerator, which was oil not reaching the rockers straight away. This sounds like that, it's quite loud, but is consistent. I would hope that it is normal, and the diagrams explain that.
Unfortunately getting the bonnet opened and closed is not easy as the catch sticks, you have to prize it open, and close it and wait for it to pop open and close it again. I plan to get that issue seen to on it's first service. 🤣
The tapping now seems to continue with driving, I've had the window's open and I'm sure I can stil hear it, it's as if there's no oil, but there is. Furthermore, lately it is now reverberating through the exhaust, so from behind the car it's luke a loud knock.
