Hi guys,
Got a leaking front crank seal on my 2005 156 2.0 JTS.
In order to replace it I got to get the timing pulley off. It’s mounted with a M16 left threaded bolt at the end of the crank axle, (timingbelt side) - but I can’t get the f.... bolt off....!!!
Made a special tool to fix the pulley, keeping pulley and crank from turning.
Been using my (300Nm) air wrench tool – but the bolt just won’t give.
I have read some were that the bolt can be tightened with up to 500Nm. (?)
Are there any special tricks or any other method to get the crank bolt off…?
I have access to a much more powerful air wrench (950Nm).
Is an air wrench, the way to go’ - or is there any another way…??
Thanx!.
Thanx!.
